Installing a factory RSCS front splitter
I have a question to anyone who has a factory 3 piece RSCS front splitter installed. Do you have a splitter and reinforcement underneath the three piece splitter? I noticed in the PET that there are two other parts for this. Do you need them?
Also, are there other parts needed for the center piece to mount it to the front of the car other than the end mounts to the side pieces? It looked like it from the PET.
Thanks!
Thanks!
I don't have RSCS front splitter but I did installed the Aerokit I which has front splitter.
The kit came with 2 extra taps for securing both splitters to the center piece, one for each side and it's secured by a screw and self-adhesive. I did not use them because I was lazy <img src="graemlins/sleep.gif" border="0" alt="[sleep]" /> .... I just lined them up and secured them with mounting tapes inside(backside). The center piece did not have more piece to help secure in place...
Of the 2 pieces that was replaced, both were direct replacement with all the screw holes predrilled and all lined up correctly, I would think the center piece would be the same as the other pieces...
Hope that helps...
Hope that helps...
