Immobilizer code
Let me try this again. I have had my 1997 993 for a little over 2 weeks. Unfortunately, I do not have an owner's manual and cannot get one from any source, including Porsche. I have the Drive Lock dearm code, but don't know the procedure to enter it.
Does the manual explain the procedure? If so, can someone give me the information.
If anyone has an extra manual - I would love to buy it!!
Thanks!!
Thanks!!
Unlock lock unlock the door with the key within 5 seconds this overides the alarm.
Within 10 seconds turn on ignition - immobiliser warning light on.
Within 100 seconds enter 4 digit code, if above times exceeded alarm will go off.
To enter code - if warning light (immobiliser) is off turn ignition off then on to get the light back.
Light starts to flash after 10 seconds you have another 5 to enter the digit.
Digit is entered by switching ignition on/off,start with left number and repeat process, once you have entered digit wait for warning light to come on before starting the next one.
( 0 = 10 on/offs )
The automatic activation function is not disabled by the manual overide.
This info is from the manual for a UK car.
Tim.
( 0 = 10 on/offs )
Tim.
