Is it beneficial to run with 18's for DE?
Basically I'm considering buying new rims for my car, ie. Fikse or Kinesis in 18"s.
Or should I just buy standard 993 17"s with DOT spec tires?
TIA.
TIA.
Robert - Thanks. I knew better. My bad.
DJF1 - I've been on TWS once in a friend's 993 and a couple of times with my motorcycle.
<a href="http://raceshop.org/motorcycle/events/track/20april02TWS/20april2002.htm" target="_blank">http://raceshop.org/motorcycle/events/track/20april02TWS/20april2002.htm</a>
I strongly recommend running 17s on the track -- be they on oem Cups or lighter aftermarket wheels. You probably won't notice the difference between 17s and 18s. More importantly 17" tires are cheaper - you'll thank us later.
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by nota_troll:
<strong>How do you know them? Haas, Brenno and I did that trackday. I almost bought Haas' 911.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Too bad you didn't - I know he's not happy it wound up w. a cage installed.
I met Haas through Dave Mundy, and PCA events; he's been instructing at DEs for quite a while.
let's spend a second on the theory about 17" vs. 18" wheels.
- The lighter the wheel the better
- The larger size wheels provide stiffer sidewall resulting in better turn-in
- The smaller the overall circumference (height of tire+wheel) the less energy it takes to turn the wheel a rotation
- The less tire width you have (in the rear) the faster you accelerate but handle worse. so this one is a trade off
- The larger size wheels correspond to less tire weight (assuming you are maintaing the same overall circumference).
So assuming this is correct & that you are not optimizing for cheaper tires but rather performance. would it be reasonable to say:
- the technology hollow spoke 18" wheels weigh less than the cup wheels.
- the added width of tire sizes may slow your acceleration a little but make up in imporved handling.
- the 18" tech. wheels will provide stiffer side walls
so for the most part i would say that 18's are superior to 17's.
what am i missing?
Cheers,
Boris
what am i missing?
Cheers,
Boris
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Boris Teksler:
<strong>
what am i missing?
</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">How expensive 18" track tires are compared to the 17's and the ultimate use of them. Looking for 10nths get the 18's and racing slicks. Looking for fun stay with the 17's and enjoy the savings.
<strong>
what am i missing?
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by DJF1:
<strong> </font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Boris Teksler:
</font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">How expensive 18" track tires are compared to the 17's and the ultimate use of them. Looking for 10nths get the 18's and racing slicks. Looking for fun stay with the 17's and enjoy the savings.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Yeah. I keep coming back to this one. Not sure how readily trackside 18" tires are.
As one who runs 18's I will say the tires are much more expensive. And while there are the advantages cited by Boris I don't think you'll be able to tell the difference- and this is after all a DE event and not a race.
Having said that I would buy the lightest strongest wheels you can afford. A number of folks have told me about Porsche replicas failing at DE events although I've never seen it myself. And I do think you could tell the difference between a heavy and light wheel given the same tire- I know I could.
