Doctor, My Battery Is Dying!
It looks like after 9 years of reliable work the battery's life in my 993 finally started to fade out. If I don't run a car for three-four days the battery gets completely dead. While it is very rare occasion when I don't use the car for such a long time like three days in a row, I am thinking that the main reason why the battery gets so weak withing few days of not operating is its age.
I would appreciate if someone would make a recommendation on the battery replacement. I probably would rather choose bigger but longer scheme instead smaller and lighter one. It appears to me that in next few months the occasions of not using a car for several days will be a common. So I would need to make sure that even after a week of not operating the car will start.
It would be great if you could specify the brand and model name of the battery... and at which store it could be purchased.
I would be deeply interested to find out any additional tricks/tips on choosing the battery, installing it, ticks of preparing the car for 7 days non-operatable parking and etc...
Thanks in advance!
Thanks in advance!
An Optima battery is a great choice, no acid spill or throughup possibility. I'm getting one for Christmas. You spend tens of thousands on the car, the last thing you want is battery acid in your trunk. You should also invest in a battery maintainer. The Porsche one is great you just plug it into your cigarette lighter when you park in your garage -- couldn't be easier.
By the way, the stock vent tube simply vents into the fender area -- it ends where that plastic 90 degree fitting at the end of the tube goes into the fender. I added tubing to the other side and routed it to the outside through the vents in the lower bumber cover.
Virtually any new battery you put in will be able to withstand weeks and weeks of non-use. 9 years on a battery is almost unheard of... 3 or 4 years is the typical lifespan.
My concern is with the readiness codes in your computer. I don't know if you have an OBD I or OBD II (you didn't mention the year of your car), but when you disconnect the battery, you may have a lot of trouble getting the readiness codes to reset, which may affect your next smog check. Maybe others who have been through this can describe this better than I.
Yes, beware the dreaded OBDII readiness codes! ( Check recent thread for more info ).
And in the "for what it's worth" department; I have never been dissappointed by the great product performance and service from Sears when it comes to auto batteries. $100 and an 8-year no-quibble warranty works for me, anyway.
Good luck
Good luck
I put a priority start unit on my Optima. I know it works because it has disconnected the power. You just hit the brakes once and it reconnects power and battery is fine since it does not get completely drained. Here's link about how it works.
Priority Start LInk
Priority Start LInk
Sputnik, Here's a good link
https://rennlist.com/forums/showthre...hlight=Odyssey
Also, for the right DIE HARD MODEL(DIE HARD INTERNATIONAL):
http://www.sears.com/sr/javasr/produ...ve%20Batteries
