993 Forum 1995-1998
Turn signals
Old Nov 27, 2004 | 07:03 PM
kary993's Avatar
kary993
Default Turn signals
Hey, I took my car out today and noticed the turn signals no longer "click" nor work outside. The lights work because the car lock blinking works and the parking light works when you have the car off and turn the signal lever in one or the other directions. I checked the fuses and nothing was blown. Anyone have any ideas? BTW, everything else seems to work fine.
TIA
Old Nov 27, 2004 | 07:06 PM
Tom W's Avatar
Tom W
Bad ground?
Old Nov 27, 2004 | 08:07 PM
jnor10's Avatar
jnor10
sounds like a relay problem. check under the front hood,find the relay, maybe swap with a "like" relay. I'd also see what you emergency flashers are doing. Might confirm a relay problem.
Jeff N.
Old Nov 27, 2004 | 08:57 PM
kary993's Avatar
kary993
Tom, Jeff, thanks for the input. The ground issue got me to thinking. I had disconnected the cetner console switches and the hazard switch was no longer connected. I put the plug into the harzard switch and all is well now with the turn signals!
Thank you for spurring on thought to fix it!
Rennlist is a great place!!!! Cheers!!!
