993 dash switch what is it?
Will someone tell me what switch/control is intended for the vertical rectangular area with indentation immediately to the right of the headlight switch on the dash of 993 cars? I have noticed in the brochure from 1996 a photograph of the dash from a Euro spec car and there is a switch/control, but I can't determine what its purpose is. My endless quest to convert my 993 C4 from US to Euro Spec!
I put a right oil cooler fan switch there for the right front oil cooler. I ghardly use it anymore since installing the other oil cooler on the left side, but it looks good there and is just below the oil gauges :-)
In my '94 cab it is a 3 position switch which adjusts the height of the headlight beam to compensate for additional weight in the car. It is labeled: +1, 0, -1. Do a search...there was a Rennlister a few mos ago who was looking to install this switch into his US spec car...not sure if he actually got it done.
I think that may be where the manual leveling control is situated for the Euro cars with Litronics. As I understand, euro cars with Litronics are required by the TUV to have some sort of leveling feature,(auto or manual) so I suspect this is where the control switch for manual leveling would go?
Jeff N
Jeff N
