2001 turbo wheels on my C2S
I have a set of hollow spoke turbo wheels and tires off a 2001 tt. I am going to put them on my C2S. Other than they rear wheels being an 1" wider, anybody have any problems with this combo? I believe the front offset is 52mm and rear offset is 40mm. Should be fine but ? I don't want to roll my fenders or put up with scrapes.
I have a set of those same wheels off a 2004 turbo on my 1996 C4S and have no problems whatsoever. It really helps to fill out the wheel wells in the back. Go for it.
Josh
Josh
Josh..
Do you have a pic of your car with the 996TT rims on it ?? I am curious as to what the setup looks like.
Looking to replace the twists with a different look...but want a factory rim.
I will try them on the car this afternoon. Thanks for the info. Of course if they don't fit I will have to sell the car and buy the turbo they go on.
I just put a set on my car also, they fit with no problem. On a side note, the early 01' 996TT wheels were not hollow spoke. I am sure you have checked the part #'s, but for those looking to buy 01'TT wheels, my advise would be to check the part numbers first.
Scott
Scott
These wheels are hollow spoke. I have owned a 2001tt (prior to the divorice).
