changing 993 discs
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
not hard at all. the hardest part is pulling the caliper and holding it out of the way (w/out bending the brake line) in order to remove the disk. If you check p-car.com, there is a trick you can do to the shock to make this job life even easier.
No sweat
Chris
No sweat
Chris
[quote]Originally posted by Stuttgart:
<strong>discs are starting to crack on the front brakes. how hard is it/ how long does it take to change the discs?
thanks</strong><hr></blockquote>
Just because they have cracks doesn't mean you need to change them. If the cracks don't connect to each other or to the outside edges you MAY be fine. You need to check the thickness of the rotor, there is a min. spec. and that is what you should use to determine when they need replacement.
Passed On
[quote]Just because they have cracks doesn't mean you need to change them<hr></blockquote>
Well, just for info the shop manual sez (in BOLD print) to replace them if the cracks are greater than 5 mm long. Think this is about the hole diameter.
