993 Forum 1995-1998
Help: Alarm Gone Crazy
Old May 18, 2003 | 11:45 AM
911sickness's Avatar
911sickness
Unhappy Help: Alarm Gone Crazy
Hi guys,
My alarm went crazy after I used the key to open the door in my '96 C4S. So here is the sequence of events.
1) lock car with transmitter but car refuses to unlock using transmitter. I could hear audible clicking sounds as the signal was received but no unlocking.
2) frustrated I used the key to open the door and of course, the alarm goes off. initially, not knowing the arcane procedure porsche describes in the owner's manual I sure I screwed up the sequence of events to enter the key code. After carefully reading the procedure, I am still confused because the lights do not come on and off as described.
3) after several unsuccessful attempts to enter the key code, I disconnected the battery. now the car is sitting immobile in my garage.
Any suggestions?? Any way to defeat the system so I could drive the car to the dealer?
Thanks <img border="0" title="" alt="[Frown]" src="frown.gif" />
Old May 18, 2003 | 11:52 AM
Terry Adams's Avatar
Terry Adams
Veteran: Army
Post
Worst case, there is something wrong with your alarm. Best case, your remote needs a new battery. Either way, I am afraid you are already down the road of having to do the arcane procedure described in the manual.
Old May 18, 2003 | 01:38 PM
STLPCA's Avatar
STLPCA
Addict & Guru
Post
There is no way to "bypass" the system. Make sure your car battery is well charged. Reconnect the battery, then attach a charger & then retry the alarm function. The Drive Block system will not function properly w/a weak car battery.
BTW, I would not leave the car battery disconnected for a long time. That can cause added problems.
