993 Forum 1995-1998
Battery vent tube
Old Aug 24, 2001 | 10:33 AM
Tom T.'s Avatar
Tom T.
Post Battery vent tube
Hi,
Cleaning out my trunk yesterday I noticed
the battery vent tube was not connected. When I tried to connect it to the battery, the connector's end was a different shape than the Interstate battery's. Has anyone connected this tube to an after market battery? if so how did you do it?
TIA,
Tom
1995 993
Old Aug 24, 2001 | 11:27 AM
GeoC2cab's Avatar
GeoC2cab
Post
Hey Tom,
I replaced a dead battery a few years ago, and used a factory battery,odd enough it didnt even have a vent connection, so i tucked the hose behind it, and have not connected it in years and every thing seems fine, when I first replaced the battery I was a little paranoid, but nothin ever happened so I guess I can live with it....
Where in NJ are you?
Old Aug 24, 2001 | 11:38 AM
Tom T.'s Avatar
Tom T.
Post
Originally posted by GeoC2cab:
<STRONG>
Where in NJ are you?</STRONG>
GeoC2cab,
Thanks for the info. The vent tube is probably not that important. Since it is there I would prefer to hook it up.
I see you are from Butler. Right now I live in Mahwah, probably only 20 minutes from you.
Tom
Old Aug 24, 2001 | 12:36 PM
Mac's Avatar
Mac
Post
There was a thread on this from the old board and I would seriously rethink the importance of the vent tube.
Its purpose is to shunt hydrogen gas away from the enclosed space. Recall the Hindenburg? Hydrogen gas trapped inside the electrical compartment (993's harness, fuse box and termination points all are in this area) is a recipe for disaster. Now I know its just a little gas, a big space and fairly unlikely....but few things in life are more exhillarating than exploding sulfuric acid lead shrapnel rocketing towards your eyes.
So, drop by your hardware store and by several sizes of vinyl tubing. These can be nested inside eachother to fit a variety of different ID's of vent tubes. Alternately, you can drop by a pet store, and go to the aquarium department for tubing size adapters.
Interestingly, some aftermarket batteries (Pep Boys) have vent tubes at both ends of the cell bank, in which case those can be connected to a single tube with a "y" connector. On the batteries which have no vent tube, nothing is needed as these are trully sealed units and the H2 gas is recycled with the cell's chamber during the charge/discahrge cycle.
Old Aug 24, 2001 | 06:32 PM
Timothy Stewart's Avatar
Timothy Stewart
Post
I have an Interstate.
The battery's black rubber tube (~5") connects to the clear vent tube via a ribbed
internal plastic connector. Looks like
the same type of connector you might
see at a hardware store in the sprinkler
section.
tim
Old Aug 24, 2001 | 07:41 PM
Travis.'s Avatar
Travis.
Post
I just replaced my battery with a porsche battery. It was cheaper than the Optima and fit was perfect. (114 vs 135)
My vent tube connector was busted so I got one from the dealer. Connector fit was not great, just shimmed it a bit to make a tighter fit.
If you don't have the connector or the one in the car doesn't fit, try the dealer? They didn't charge for one...
good luck!
-travis
Old Aug 25, 2001 | 02:31 AM
Pete Lech's Avatar
Pete Lech
Lifetime Member
Post
My connector was missing from the tube when I got my car, so I used a 90 degree ell made for drip sprinklers. Applied a little heat to make one end oval to fit into the battery vent.
I had never seen one of these tubes, and thanks to the group here, it was identified for me.
Old Aug 26, 2001 | 12:08 AM
Carmen's Avatar
Carmen
Post
Tom / Geo - North Jersey here also - Riverdale to be exact.. practically Neighbors ...
Meet?
Old Aug 27, 2001 | 10:36 AM
Tom T.'s Avatar
Tom T.
Post
Originally posted by Carmen:
<STRONG>Tom / Geo - North Jersey here also - Riverdale to be exact.. practically Neighbors ...
Meet?</STRONG>
Carmen,
Riverdale is right between me and Geo. Would not mind meeting up sometime. Any suggestions as to a place?
Tom
Old Aug 29, 2001 | 12:10 AM
Larry 97C4S's Avatar
Larry 97C4S
8th Gear
Post
Tom,
I noticed the same problem on an Interstate battery installed by a previous owner on my '97 C4S. I went to my local Interstate dealer, and he supplied me with a free adapter to route the OEM vent line to the side-mounted vent on the Interstate battery. Two minute fix and free.
