Strange Noises After Lightening 993
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
Has anyone who has lightened their 993 experienced substantially increased noise emitting from the back seat area (sounds like alternating hissing/sucking noises). I just removed the rear fold down seats, all rear seat belts, spare tire, trunk carpeting, windshield washer reservoir/motor. My guess is that it may be coming from the rear seat belt bolt holes but I'm not sure. It is a 1997 S. Any ideas?
Thanks for any help.
Jim
Jim
jw,
Just a couple of quick questions...do you have some sort of sport air filter system on the car? Does the noise vary with more or less throttle input? I'm thinking that if you have a "free flow" air filter system that noise you are hearing is the air being sucked into the airflow meter. The air filter housing/airflow meter assy. is just inches from the right side of the rear firewall and with the rear seats removed it is just easier to hear all these wonderful noises.
Q
Q
Thanks Q. Just have the optional motor sound package (drilled airbox/mufflers). I should have said that the noise becomes severe at full throttle. You may be right about the removal of the seats causing the noise. If that's it then I'll just have to live with it.
Thanks again.
Jim
Thanks again.
Jim
Jim,
I had the motorsound package and stripped interior. The air sound is exactly as you describe. I now have a cup air box and the sound is louder yet. Add the Fabspeed exhaust and you will not notice the air intake noise.
Haiku Grasshoppa
Can I Drove Your Car?
Yep, my car does this too.
I thought that it must be air getting sucked through the seat-bolt-holes. Bill's right: put the Supercups on, and you won't notice that sucking sound.
after you removed that much sound insulation and sound deadening material........your Porsche mufflers now allow you the hear the engine sucking in air thru the airfilter housing. I like the whistle and instaneous whistle & sound that is electrically connected to the gas pedal.
Fabspeed Motorsport USA
155 Commerce Drive
Fort Washington, PA. 19034
www.Fabspeed.com
P: 215-646-4945
F: 215-646-9828
Exotic Car Performance Experts
Porsche, Ferrari, Lamborghini, McLaren, Maserati, Bentley, Aston Martin, BMW, Audi and Jaguar.
31 year PCA Club member supporter
14 year Ferrari Club member
1st ever financial supporter of Porsche Fans/ Rennlist
155 Commerce Drive
www.Fabspeed.com
P: 215-646-4945
F: 215-646-9828
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Thanks for the help guys. I replaced the rear seat belt bolts/rear seat bolts with plastic screw in caps (from Ace hardware) and the sucking/hissing is gone. I wouldn't mind increased engine sounds but the sucking/hissing noises had to go.
Thanks again for the help.
Jim
Jim
Hi Jim. I just took my kids for a weekend away in my C2S and they were complaining about the same noise you're talking about. Can you elaborate on which holes you plugged? I took out the seat backs to get more room for their car seats, but of course, the seat belts are still in.
Thanks,
John
Thanks,
John
Hi John
The local hardware store (Ace Hardware here) has small threaded black plastic caps (similar to a bolt but plastic) which you can use to thread into the rear seat bolt holes. I believe the hole size is 5/16. I cut a small groove on the top with a dremel so I can screw them in tightly with a screwdriver.
Good luck
Jim
Good luck
Jim
