CDR 210 Question
Does the FM tuner button on this unit light up? The volume button is lighted on my unit but the tuner button is not. If it should be lighted, has anyone ever replaced the bulb for the button? Thanks in advance.
Mine does not light up either. Not sure if its supposed too, I actually took it apart to fix and could not find a bulb or LED. I did not find one on the volume side either so I am not sure that says anthing...
Below is the response from Becker USA. I'll just leave mine dark rather than spend what is probably a ridiculous amount to get it fixed.
"Both sides should light up equally. It is not a simple repair you can do yourself. You should send the unit to us with a note containing your name, shipping address, and method of payment. I am not sure of the repair cost so you may want to request an estimate."
"I am not sure of the repair cost so you may want to request an estimate."
When THE repair shop tells you that you just have to know it's gonna cost some $$'s...
