Anyone added an aftermarket amp to a CDR210?
The title says it all. I'm trying to use a Becker CDR210 with a more powerful aftermarket amplifier. Thought the 993 board might be more helpful as most of these units were in the 993's. TIA
I did this at one point Roy. Be sure you get the Becker pre-amp outputs so the head unit can connect directly to an amp without some other contraptions.
You can get them through http://www.beckerautosound.com/
I also replaced the OEM speakers and this made a significant difference in sound quality.
Good luck and enjoy.
-Skip
-Skip
Here's the guy to talk to. Yes, he is a Rennlist sponsor.
http://www.caraudioinnovations.com/
I just switched to an understated looking Nakamichi head unit and an eclipse amp. It sounds a lot better than the Hi-Fi option equipment that was in the car, while still retaining a very "stock" look.
