993 Forum 1995-1998
Rear Seat Delete
Old 10-11-2004, 05:23 PM
nman413
nman413's Avatar
touf, take a 17mm (IIRC) and start unscrewing. The seat backs come out pretty easy.
You will need to undo the rear shelf to take the seat belts out.
Old 10-12-2004, 05:21 PM
touf
touf's Avatar
Getting the rear seat belts was easy. removed the rear panel (held by 4 Philips screws) and removed the seat belts (held by 17mm bolt)s.
How do I remove the seat backs?
Old 10-12-2004, 05:25 PM
Racer944
Racer944's Avatar
Quick question related to this thread...
Anyone know if the "seat delete" work with a DAS bolt in Roll bar? I guess the real question is are the rear set belt mounting spots still available with the delete kit in place?
Old 10-12-2004, 05:43 PM
TheOtherEric
TheOtherEric's Avatar
The rear seat belt mounting points are NOT accessible with the kit in place. Like Kim said, you'll have to cut thru or else remove it.
Old 10-12-2004, 05:49 PM
Racer944
Racer944's Avatar
Thanks guys;
I kind of figured I would have to cut a bit... I guess I was more concerned that the unit might need the belt mounting points to attach itself.
Old 10-12-2004, 05:54 PM
24FPS
24FPS's Avatar
has anyone removed the seats & simply re-carpeted???
was curious what kind of weight savings this might be as (i think) the 'delete kit' still weighs quite a bit... & is made of what? (wood?)... seems like i heard this somewhere along the threads.
as always... thx for input. cheers.
Old 10-12-2004, 06:10 PM
24FPS
24FPS's Avatar
wow! you are the bomb! bet it sounds great too! -- weird, thought there would be even more of a weight savings than that (still pretty damn good) .... btw: kim where can one get an 'rs' carpet kit? (even avail?)
thx!
Old 10-12-2004, 06:16 PM
TheOtherEric
Couldn't agree more with Kim- the RSD kit weighs probably 30+ lbs. Hard for me to say exactly since mine has subwoofers bolted to them.
Old 10-12-2004, 06:47 PM
24FPS
24FPS's Avatar
thx guys & sorry for hi-jackin' a bit (o.t.)... by hey... if ya' don't ask, you don't get. right?
cheers.
Old 10-13-2004, 02:09 AM
Jean
Jean's Avatar
Kim
Thank you for the information, I have been trying to get my hands on this as well, I should have thought of the Director of parts earlier
Is it bare metal under the rear deck and seat-back carpet or do you have the stock leather piece underneath and the carpet on top? I have all the rear stripped to the metal, and wondering how to go about it.
Thank you.
Jean
Old 10-13-2004, 02:25 AM
Jean
Jean's Avatar
Kim Thanks so much for the info, it is very helpful.
Old 10-13-2004, 04:37 AM
David in LA
David in LA's Avatar
Originally Posted by Racer944
Thanks guys;
Yes that is correct...the RSD has a strap on each side that is bolted onto the side seatbelt mounting holes.
Old 10-13-2004, 09:27 AM
Flying Finn
King of Cool
Flying Finn's Avatar
I've also removed all the stuff back there, problem is, I haven't re-carpeted everything back yet so it's bare metal and some wires...
Thanks to the upholstery link by Kim, maybe finally I can get some carpet back there.
Originally Posted by Wreck Me Otter
Yes. I have the RS rear deck carpet, probably saves 10-12lbs (no speakers and no rear deck panel). I also have removed the seats, sound proofing, and the heavy rubber insulation. That savead another 20lbs for the entire interior, maybe 10lbs of it was from the rear alone.
I would not put the delete kit in if you're thinking of weight savings.
Old 10-13-2004, 09:42 AM
Jean
Jean's Avatar
Sorry for the OT, but while it is stripped, I discovered two holes in the back, large enough to slip through them Moton canisters, it is where the wiring harness goes from the engine through the cabin. No more holes to drill
Old 10-13-2004, 01:07 PM
Jean
Jean's Avatar
Kim,
I will post pics as soon as I go to the workshop tomorrow. They were on the sides, almost at the top of the back metal sheet, covered with rubber. You will have to disconnect the wiring harness to slip it out of the hole for better fit.
I spoke to Jerome in the Netherlands, the owner of Moton and he discouraged me from disconnecting the hoses even if I am knowledgeable (not that I am!). I know some people have done it, but that's what he said.
Will report back.
Quick Reply: Rear Seat Delete
