993 uneven braking
993 uneven braking
What would uneven braking in a 97 993 Cab suggest? When I apply the brakes it feels like something is catching every 2-3 seconds or so (obviously is speed dependent - occurs every time I brake) Car recently purchased with 29K miles had 30K service done and independent PPI.
Mark Jordan
Mark Jordan
Hey Mark,
Your post is a little hard to understand.. Uneven braking??
My guess would be you either need to replace your brake pads or your rotors. Or it might be a much simpler problem like you need to spray some brake cleaner.
It sort of sounds like you have some sort of uneven pad deposition on the rotors. Do the brakes make a lot of noise? Does the car shake when you brake?
I would not hesitate to bring your car to a mechanic and have them look at it immediately. After all, your brakes are the most important thing on the car.
Good Luck.
Good Luck.
