993 Forum 1995-1998
Got my car back! Re-gearing done!
Old 09-24-2004 | 11:27 AM
  #46
garychios's Avatar
garychios
Add the supercharger I am looking at, and my car should move finally
Old 09-24-2004 | 11:28 AM
  #47
akolodesh's Avatar
akolodesh
thanks for the info Greg. Any reason for not adding 1st and 2nd gear steel synchros?
Old 09-24-2004 | 11:30 AM
  #48
akolodesh's Avatar
akolodesh
oh yeah..... Greg, a ride in your car at Putnam next weekend? Hmm let me think about it a moment............... HELL YES!
Old 09-24-2004 | 11:32 AM
  #49
Greg Fishman's Avatar
Greg Fishman
Alex,
Mainly cost, IMO. The second gear Motorsport synchro is a three piece unit that costs around $1500. If you aren't going to track the car a bunch and know how to downshift correctly then it doesn't make sense ($$) to use it. In a race car you wouldn't think of using the brass synchros IMO.
Old 09-24-2004 | 11:38 AM
  #50
Greg Fishman
Bring ear plugs! Not sure who your instructor is going to be but I would be happy to ride with you as well. It is always a good idea to get more than one view point.
Old 09-24-2004 | 11:41 AM
  #51
akolodesh's Avatar
akolodesh
Old 09-24-2004 | 01:31 PM
  #52
993RS's Avatar
993RS
Originally Posted by Toga
Already back? Hungry maybe?
Thanks for the info. This is my first Porsche, so I don't have any reference. It goes well, but how well...that's the question.
Sorry but one more question: the measurement is done engine in place? How do they do it? Do you know?
Nice pictures BTW.
Cheers
They have to take out the engine to do the measurement. Takes about half a day...
Old 09-24-2004 | 01:34 PM
  #53
993RS's Avatar
993RS
Regarding the steel synchros: my assumption had always been that the steel synchros provide for a more "crisp" move through the gear ratios. Is this correct? I had also assumed that steel synchros could become permanently damaged if gear grinding occurs (hence not doing the 1st gear). I see that you did 2nd. Any concern regarding this gear? Also, you changed out your 5th to 6th but went with a steel synchro (thereby negating the cost savings from using the old synchro). Any particular reason for not utilizing the brass synchro on the top cruising gear?
I just followed Steve W's recommendations. Just decided to go whole hog and get steel synchros for 2nd - 6th.
  #54
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Originally Posted by flatair
Oh yes,....there are lots of options,....
Is it me or did I just hear Steve emit a mad echoing cackle of laughter (followed by manic rolling of hands)
Oh BTW, hows highway cruising with 5th as top gear?
Ahhhhh,...you are a VERY perceptive person,...
As for cruising along in 5th gear, try that for yourself; simply quit using 6th gear for a few days and see if that works for you.
Old 09-24-2004 | 01:35 PM
  #55
993RS's Avatar
993RS
Cruising with 5th is fine. (In fact many times I would forget to shift to 6th...)
Old 09-24-2004 | 01:36 PM
  #56
993RS's Avatar
993RS
I have driven a couple turbos and I just really didn't see an obvious need to re-gear them. They have so much torque that it really didn't seem to bother them like the NA cars. If anything the Turbo needs taller first and second gears as it runs out of them so quickly.
It was probably justifiable with the early turbos which had only 4 gears....
Old 09-24-2004 | 01:38 PM
  #57
993RS's Avatar
993RS
Originally Posted by lowblow
Phil-
Didn't i once read that you were done with modifications?. That's o.k, I understand. I had a long conversation with my independant yesterday about doing the 3.8 with supercharger conversion to my C4S.....Now, just need +/- 20K!!!
mike
True, but then I tried out the 997 Carrera S and decided to do something to even up the score somewhat...
  #58
Greg Fishman
Very true, I know several that made that change. I think he was referring to a 993 Turbo though.
Old 09-24-2004 | 02:37 PM
  #59
mnmblu's Avatar
mnmblu
Phil,
I am dyin here. I am day dreaming about screaming through the Alps in that snarling beast. You lucky devil you.... Have fuuuuuuuuuun and hurry up and get those sway bars. Can't wait until you kick the tar out of a 997 goin up an on ramp. Hey kids, it's time for: Phylin with Phil.
Old 09-24-2004 | 05:12 PM
  #60
993RS's Avatar
993RS
Actually, the 997 Carrera S is pretty formidable, since it not only has 355 hp but much shorter gearing than the G50/21 (or 996 for that matter). In fact, my gears are shorter but not by much...
Gear.....US/Swiss......Rest of the World ......
______(G50/20)________(G50/21)______997 S_______996_______Steve's Recommendation for my 993
1.......3.818..................3.818.......................3.91......... .......3.8................3.818
2.......2.048..................2.150.......................2.32......... .......2.2................2.25
3.......1.407..................1.560.......................1.61......... ......1.52...............1.68
4.......1.118..................1.242.......................1.28......... ......1.22................1.3
5....... 0.962.................1.027.......................1.08................1. 02...............1.1
6........0.775.................0.820.......................0.88......... .......0.84...............0.962
Final ratio 3.44:1 for all models
Quick Reply: Got my car back! Re-gearing done!
