Need Hardware - Try CAT
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
Many times folks ask where they can get grade 8 or better hardware. I'm sure that there are many sources, but there's a place "down the street from you" that has (or can get in 24 hours) just about any hardware you might want. I use my local CAT dealer for everything including those pesky bolts that secure the seat to the floor.
When I installed "flat D rings" under 3 of the 4 corners under my seat, I went looking for slightly longer seat bolts than stock in order to have the designed thread engagement. I not only found the required bolts, but I got some washers to go under the seat rails for the other 3 of the 6 mounting bolts. This was to assure there wouldn't be any twisting of the seat rails when I installed the rings.
The cost of the hardware is very competitive.
Here is a link to the CAT web site that shows a few pages from their "One Safe Source" catalog listing hardware.
<a href="http://www.cat.com/products/shared/parts_n_service/07_hardware/images/hardwre.pdf" target="_blank">CAT Hardware</a>
If it'll last on a D11, it will last of a 993. My only affiliation is 30 years of employment.
<img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
