Convertible Top Care - ideas welcome
From: Los Angeles, CA (Brentwood) & New York, NY (Tribeca)
What products do you recommend for care of the convertible top and how often should they be applied? I've used Groit's plastic window cleaner with success, but I haven't yet treated the cloth material. I've seen a few scattered references to this topic - yes, I did search.
Should I lubricate the convertible top mechanism cables? My top creaks a bit when in the raised position and I wondered if that might help.
Not sure about the lubrication, but I ordered the Porsche Cabriolet top cleaner, masked off the entire car, and sprayed about half the bottle. Used the Porsche cleaner first...seems to do the trick nicely.
<a href="http://www.autopia.org" target="_blank">www.autopia.org</a> is the guru place for detailing...one of the moderators, BradB has a 993.
From what I have learned from Autopia and personal experience use Plexus with a quality micro fiber towel to clean your plastic window. It must be dust free before raising the top or you will get scratches. I stop the top at 90 degrees and make sure the window is folding evenly, if not you will get a white crazing which will not come out. I alway use the boot to save the headliner, and never leave the top down over night. Meguirs #17 Plastic cleaner or Renovo works well for removal of fine exterior scratches.
I use Wolfstein's Raggtopp cleaner and protectant for the fabric. No masking necessary which makes it much easier to use than the Tequipment product, as well as a better deal. I believe I bought this stuff at Autofanatics.com
2002, 993, 996, cables, cabriolet, care, convertible, covertible, creaks, lubricate, maintenance, microfiber, plexus, porsche, rennlist, seal, top
