I am looking to install an in-dash video unit for GPS (Alpine makes a few) and such but was not sure if the screen will hit the dash when it flips up. Anyone using one of these?
Do a search as this has been discussed before. Mounting the unit in the stock radio location will result in the screen hitting the dash. Your options are to either notch the dash and make a cutout (a rennlister has done this and has posted pics); or install the optional center console (which has a mount for a cell phone) that has room for the monitor. Good luck and post pics if you decide to do this.
I have done such installs with all of the alpine flip-out video pieces in porsches. The bottom line when installing these units in this application is the understanding that you are going to lose the airvents. If you remove the center vent cluster, you can slide the mounting sleeve in the opening, with very little work. The end result is very user friendly and the screen location higher on the dash is a big plus. Also this now frees up the oem din location for an in dash DVD player or navigation drive.
can anyone tell me what is involved in gutting out the air vents to make way for a flip screen.
And can this be reversed when i decide to sell the car. is it just a matter of poping it out or do you have to cut it out?
