Carbon Fiber Shift Knob
Carbon Fiber Shift ****
I picked up a Momo Carbon fiber shift **** at the German Autofest. When I got home I took a look at the shifter I have and noticed that the leather boot is one piece with the shifter ****.
My question is do you have to cut the leather and than stuff it under the mounting ring of the new ****?
What have other people done?
that's correct one piece. don't cut anything, just with firm pressure push against the bottom base with a sideway pressure. it takes a good deal of pressure but you will release the existing shift ****. then you will place the new one in and get it into the clips and pull up on the leather.
i think there is a DIY on pcar.com
hope that helps.
cheers,
boris
hope that helps.
cheers,
boris
this is a really old post but I am looking into doing an aftermarket **** and my shifter boot/**** is also one piece...there is no diy on p-car.com...so did it work Randy?
