Clarification on RS Pulley...
About to do the single belt upgrade.......
Just want to make sure I DO NOT NEED to replace the pulley at the crankshaft and ONLY need the RS Alternator Hub in the fan shroud ??????? 993.106.051.80.
A few posts in the Library were unclear as to definitively needing both parts.
Can anyone clarify ????
FWIW....pricing for Crankshaft Pulley is stupid expensive at over $500 bucks....
RS Alternator Hub(pulley) more reasonable at $150.
Thanks for your help !!!
Keith,
You can just change the alternator pulley mount. You do not need to change the crank. There are numerous posts in the past here with DIY info. I know that jeff993tt had one somewhere...
Simple procedure. Should take a couple of hours.. Good luck...
