993 Forum 1995-1998
Big Reds Installed...almost....advice requested...
Old Aug 11, 2002 | 12:30 AM
Wreck Me Otter's Avatar
Wreck Me Otter
Default ...
Old Aug 11, 2002 | 05:40 AM
CalvinC4S's Avatar
CalvinC4S
Post
I would check it for kinks, then make sure it is dry around the fitting. Take it for a test drive then check it again for moisture. If there is something wrong with the line you will know right away. The car will want to pull when braking. I have done a few "big red" upgrades and had to bend the lines by hand. I know what you are feeling.
Also, be sure that the rotor vents are facing back, a lot of people goof-up and do not relies they are directional.
<img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
Old Aug 11, 2002 | 05:43 AM
CalvinC4S's Avatar
CalvinC4S
Post
Oh, another trick is to get the line started befor you mount the caliper down. Also, be sure to bleed both halfs of the calaper inside half first.
Note, I dont know your technical level, just some things I wish I knew my first time
Old Aug 11, 2002 | 02:56 PM
CalvinC4S's Avatar
CalvinC4S
Post
Hey Kim,
Are they OEM pads? The factory just uses the dampner discs to the pad. I never remember seeing another shim type dampner? That is with the OEM and Pagid orange.
Old Aug 11, 2002 | 05:06 PM
Jack's Avatar
Jack
Post
Kim:
It's about time you got those Big Reds on your car. BTW, those calipers/pads never made any noise on my old Turbo. Enjoy.
Old Aug 11, 2002 | 09:12 PM
M. Schneider's Avatar
M. Schneider
25 Year Member
Post
Hey Kim:
Would you know if the 17" cup wheel would fit over your "Big Reds" & rotor enhancement? Just a thought for us who need to fit snow tires in the fall.
Additionally, would you know if the stock 993tt rotors and the Porsche Motorsports 993 rotors are the same diameter?
TIA
Old Aug 12, 2002 | 12:35 AM
GeoC2cab's Avatar
GeoC2cab
Post
High,
17" rims will fit over big reds, they do on my car., but it''s a 964....that shouldn't make a difference.
Old Aug 12, 2002 | 01:53 AM
Robert Henriksen's Avatar
Robert Henriksen
Post
It's a wise man who knows when to be afraid...
I replaced my front rotors today. And even though I used new caliper bolts, and quadruple checked the torque, and the wheel lugs, and pumped the brake pedal before driving, I *still* felt paranoid <img src="graemlins/oops.gif" border="0" alt="[oops]" />
Old Aug 12, 2002 | 01:54 AM
Phil's Avatar
Phil
Phlat Black Guru
Lifetime Member
- Times 2
Post
congrats Kim......are you happy with all that work?....next project the 3.8 upgrade?
