Part #'s needed please...
I just noticed my passenger side valve cover gasket is leaking. Drivers side is bone dry.
I have the DIY info from Robin, but there is no part # listed and a search turned up nothing either.
Can someone give me the part #'s for each gasket (if different), and the new 5mm Allen Bolts? I figured I might as well do both sides while I'am at it.
Also, some folks have taken off the heat exchanger and/or muffler, and some have not. Any tips either way?
TIA.
TIA.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
TIA.![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
TIA.
The mufflers are straightforward.
TIA.
Edit: oops, VB beat me to it w/ actual part #'s!
On a side note, the biggest problem I had with this DIY was that while I was under the car I noticed one of my plug wires had split, so I ended up replacing it. Now that was a PITA!
Thanks to all !
Troy - I too saw one of my plug wires had a split in the black jacket at the bend. I was hoping to not have to change these but may have to. I suppose I should think about the plugs while I'am in there...Doh !
Originally Posted by TroyN
By the way, the DIY on p-car.com for plug wire change was great. The stubby ratcheting screwdrivers were the only way to go (got mine at Sears). Good luck!
Troy - Were these stubbies with a socket end or a normal screwdriver end. Do you remember the part # at sears? Just wasn't sure if they were for nuts or screws, guessing sockets for nuts???
How much should I excpect to pay for a new wire set? Any good sources?
Thanks.
How much should I excpect to pay for a new wire set? Any good sources? I checked Kingsborne.com where Andy said they were $267.00, but they quoted me $587.00 ????? Then he mentioned ViperBob, but didn't know how much VB wanted, or what brand he would have for sale.
You should probably try to get your hands/arms back there to make sure it's something you should even try. Lucky for me in this case I am lean! One other thing that was not covered in the DIY was that you probably have to remove a few other parts on the driver's side, I think the heater blower. Other than that it's just a good amount of frustration as you try to get enough leverage and not drop things as you work on those brackets. It was a revelation in the DIY too that you can unscrew the plug wire ends!
Since I only replaced one wire, I just bought through my local dealer. Unfortunately I don't recall the price, or I could at least extrapolate the cost for a full set of 12. The pricing I have seen runs closer to $400-500, so < $300 sounds like a great deal. I'm sure one of the Rennlist sponsors could get you a set, but failing that you might try Sunset Porsche, which sells parts for 15% over their cost. It's a longer wait sometimes, usually 2 weeks, but could be worth it. I've bought suspension parts from them at a significant savings over the dealer.
Anyway, hope that was it, this is my second time writing this response - the first time my IE crashed when I was almost done! Ugh. Oh, and let us know what pricing you end up getting and where.
