993 Forum 1995-1998
Broken door check strap
Old 11-15-2001 | 11:25 PM
Anir's Avatar
Anir
Post Broken door check strap
At 14,000 miles, my driver's door has developed an annoying click when opening/closing due to a broken door check strap. According to 911 & Porsche World's 993 buying guide, this is a relatively common problem. They state:
"Although the replacement is cheap, you have to remove the door to fit it, so expect to pay up to $573 to have the problem rectified."
Has anyone fixed this as a DIY project? If not, what types of costs were involved? Appreciate the help.
Old 11-16-2001 | 12:13 AM
STLPCA's Avatar
STLPCA
Addict & Guru
Post
Anir
Remembered there were posts on the subject from the 993/996 Board, as well as on this Board.
Found these threads:
Door Strap
Check-Strap on door '97 993S!
and pretty sure there were others, but they may have been earlier than the start of the old archives.
Odd problem at such low miles - obviously shouldn't happen in a Neon, much less a $100k car. I guess we should all be careful when we swing our doors open.
Old 11-16-2001 | 12:29 AM
Anir's Avatar
Anir
Post
Thank you, Dan! Somehow, I didn't remember seeing old posts on this subject.
Old 11-16-2001 | 02:17 AM
jebia's Avatar
jebia
Post
I had this happen on my 86 carrera. I fixed it in about 15 minutes, with out welding. I drilled a hole slightly above the broken weld above the hinge (drilled thru the body and the hinge plate) and slightly below the weld below the hinge. I then installed two pop rivets (don't use aluminum rivets, I used stainless steel). I touched up the tops of the rivets with a bit of touch up paint. Its a cheap solution and it works.
jon
Old 11-16-2001 | 02:23 AM
Chris C.'s Avatar
Chris C.
Post
Anir:
I had a broken strap fixed on my 1998 C2S two months ago. I am the 2nd owner, and the cost to me was $0.00--covered under Porsche goodwill no questions asked (I did not have an extended warranty).
Talk with your local dealer...I believe they will cover your fix (it is a body shop repair involving cutting a into the doorjam, re welding the strap, and repainting a small area on the jam)
Good luck.
Chris
Old 11-16-2001 | 03:08 PM
Curtis - '97 Targa's Avatar
Curtis - '97 Targa
Post
Anir,
The local dealer ended up fixing mine for free, too.
Curtis
