993 Forum 1995-1998
Rear spoiler rumble when retracting down
Old Nov 13, 2001 | 09:01 PM
Rob W's Avatar
Rob W
Red face Rear spoiler rumble when retracting down
My rear spoiler 96 carrera, rumbles on its way down I can't figure out whether it's the transmission or the motor. Already replaced the nylon bushings in on the support bolts. Any help would be greatly appreciated.
Old Nov 13, 2001 | 09:33 PM
GeoT3's Avatar
GeoT3
Post
Rob,
Most likely its your spoiler trans. I had the same problem and by replacing the trans solved it.
George
Old Nov 13, 2001 | 10:33 PM
gohno's Avatar
gohno
Post
I was told that was the standard "coffee grinder" that came with the car!
Old Nov 14, 2001 | 01:40 PM
Travis.'s Avatar
Travis.
Post
My car is having the same noise. It recently just started after I replaced the spoiler wall yesterday.
See posting just a little bit lower. (thread started yesterday)
Haven't had a chance to look at it closer, but hope to get to it this weekend.
-travis
993 C4
Old Nov 14, 2001 | 01:42 PM
Travis.'s Avatar
Travis.
Post
-travis
993 C4
Old Nov 14, 2001 | 03:33 PM
Chris in Detroit's Avatar
Chris in Detroit
Post
When I replaced my spoiler wall I noticed on the left hand side lower corner it fouled / touched as it moved up and down - caused a grinding noise until I filed the offending 2mm or so down to allow clearance.
You need a helper to work the spoiler while you check carefully it isn't rubbing anywhere
