993 Forum 1995-1998
Updated alternator pulley
Old Jun 14, 2026 | 11:55 AM
TakeFour's Avatar
TakeFour
Originally Posted by NeinEleven
It's 12.7-13.4V engine running with a brand new battery
Sounds perfect at idle, if it goes up about 1 volt at 3000 rpm all is good
Old Jun 14, 2026 | 03:09 PM
pp000830's Avatar
pp000830
Hi TakeFour,
Interesting perspective.
My 1996 C2 993 never goes below 13.5 volts even at idle.
My view is that at 12.7 volts, no charging is taking place, and at 13.4, a very slow rate of charge, not enough to sustain the battery. This undervoltage may impact electrical components in the car.
Keep in mind the alternator has to produce enough voltage to power all electrical loads in the system when the engine is running AND keep the battery fully charged. Not sure an output of 13.4 volts will cut it.
Andy
