Help ... Tire Pressures
Originally Posted by L22DC4Cab
I will give 40f/38r a try in an effort to reduce understeer. I want to be careful not to induce sudden oversteer and have the rear step out on me violently.
Also unless you are tracking or racing the car IMHO you are better off NOT trying to adjust the understeer/oversteer through tire air pressures. If looking for a cost effective was to reduce understeer you should drill the rear sway bar and stiffen it. IMHO of course
Addict & Guru
Originally Posted by D.G..
I had Pilot MXX3s before the S03s. The Pilots had slightly better grip, but when they let loose there was absolutely no warning.
Addicted Specialist
Just my opinion, but I don't think 40f/38r is going to do much for reducing understeer on the street. 36psi is what's rcommended for 17"cups, and I'd stick with that, or perhaps drop the rear by 2-3 psi, but I wouldn't go higher than 36. Tires are meant to operate under specific design parameters. Deviate + or - by too much and at best, your handling suffers; at worst, your tires fail and you go bye bye. Ultimately, you really can't address understeer issue with just adjusting tire pressures, sorry! When one is already within the tires' proper inflation range, fiddling with air pressure, especially for a street-driven car, just isn't going to yield much improvement in handling, and can even result in, ahem, less-than-desirable results.
The best way to address your understeer is first, go to 225/45 fronts, as was already mentioned. This makes a considerable difference. Then you can go to bigger swaybars --there's a host of them out there, but the most cost-effective fix is M030 swaybars, 22mm/20mm, IMHO.
And also remember that BOTH understeer or oversteer can be induced in most cars, depending on driver input...just a reminder.
Edward
