993 Forum 1995-1998
rear (aux) engine blower on
Old Aug 8, 2004 | 05:53 PM
stresser's Avatar
stresser
Default rear (aux) engine blower on
Hi everyone,
I need some help with my 97 C4S. I've read all the earlier threads about this and still can't figure it out.
After starting the car and then immediately shutting off (engine still cold) the rear blower comes on and stays on for up to 10 minutes. Key is out of the ignition. I can't tell if it's low or high speed. Is this the blower relay or the temp sensor? I read about jumping the contacts that the relay fits into to diagnose, but how do you figure out which is 3, 5, 7, etc?
I would appreciate any thoughts.
Also, I need to replace or fix the driver's door lock actuator. Do I need to pull the door apart to do this?
