Enso
close
- Join DateNov 2011
- LocationSaskatoon SK Canada
Liked:64 Times in 38 Posts
Hi
wondering if I’m mistaken but it looks like door seals are much lower in cost than previous years
Pelican has the German ones for 119 US and OEM is $86
Part https://www.pelicanparts.com/More_In...=643&DID=16676
the part number seems different but they is the right one?
Does anyone know if this seal is correct or did I not get enough sleep?
kindly
glenn
kindly
glenn
boomboomthump
close
- Join DateDec 2019
- LocationNew Jersey
Liked:1,704 Times in 850 Posts
Since I knew exactly what I titled the thread... see here:
https://rennlist.com/forums/993-foru...hat-gives.html
boomboomthump
close
- Join DateDec 2019
Long story short, they discontinued the original 964/993 seals, which were smooth on the surface (964.xxx part number) with seals slightly smaller in girth, which were used on older 911's (911.xxx part number) and have a ribbed surface. They work but don't "appear" correct if that matters to you.
Some people prefer some of the aftermarket offerings of the 964 part number.
Enso
close
- Join DateNov 2011
thanks for this, very helpfulOriginally Posted by boomboomthump
Long story short, they discontinued the original 964/993 seals, which were smooth on the surface (964.xxx part number) with seals slightly smaller in girth, which were used on older 911's (911.xxx part number) and have a ribbed surface. They work but don't "appear" correct if that matters to you.Some people prefer some of the aftermarket offerings of the 964 part number.
i should have searched RL before asking🤪
