993 Forum 1995-1998
993 Pedal Cluster same as 964
Old Jul 29, 2004 | 07:09 AM
dbelleperc's Avatar
dbelleperc
Default 993 Pedal Cluster same as 964
Is the pedal cluster of the 993's the same as the 964's. And does anyone have the part numbers.
Old Jul 29, 2004 | 11:57 AM
FlyYellow's Avatar
FlyYellow
nice avatar !
i think they are the same - but not sure. Viken or Adrian will know for certain....
Cheers,
Boris
Old Jul 29, 2004 | 02:40 PM
DKP 97 C2 Coupe's Avatar
DKP 97 C2 Coupe
David,
I don't have the part #'s handy but I've worked on the pedal assy.'s on both 964's and 993's and I never detected any difference. I'd be very surprised if they aren't the same piece.
Old Jul 29, 2004 | 03:25 PM
ksimpson's Avatar
ksimpson
Just cheked PET. There are a lot of part numbers for the 993 pedal cluster. Most of them start with 993 and a few with 964. You can therefore assume that the 964 and 993 pedal cluster are not the same.
Old Jul 29, 2004 | 03:30 PM
ksimpson's Avatar
ksimpson
Edited by Admin:
From paragraph 6 of the Rennlist Charter:
"In keeping with Copyright law, Rennlist considers that the content of messages posted to any of the lists will remain the copyrighted material of its author, as the "original author", unless the author specifically assigns copyright otherwise. Rennlist is considered a "forwarder" or "publisher", and the combined "list/site messages" to be considered as "archives", protected under Rennlist Copyright. Posts containing material which is protected under copyright, which a person does not have express permission to use, resell, distribute or otherwise make available are grounds for immediate termination of that user."
Old Jul 29, 2004 | 09:12 PM
dbelleperc's Avatar
dbelleperc
Thanks, look like the base is still the 901 base, but the whole pedal assembley look like the 964. The plan I have for this is to make a hydraulic clutch set up in the 914, and the 964 pedal will work and looks like the 993 will too.
