993 Forum 1995-1998
OBD II Scan Tool For 1995 993 ??
Old 07-23-2001, 10:34 AM
911-TOUR
911-TOUR's Avatar
Post OBD II Scan Tool For 1995 993 ??
All,
Can anyone recomend a good OBD II scan tool for my 1995 993 ?? I would also potentially like to use it (if possible) on a 2000 Nissan XTerra.
Thanks for any recommendations.
sean
Old 07-23-2001, 10:36 AM
Robin 993DX
Lifetime Member
Robin 993DX's Avatar
Post
All the OBD2 scan tool that I know of (ones that uses a laptop or a hand held) will not work with your OBD1 993, but will certainly work with your Nissan if you have the right OBD port adaptor. Not sure if the Nissan uses the same ISO OBD port as the German cars.
Old 07-23-2001, 11:05 AM
911-TOUR
911-TOUR's Avatar
Post
Robin,
I thought all post 1994 cars sold in the US were required to use OBD2. At the very least I thought this was a California mandate (where the car was originally sold). Was this an incorrect assumption?
sean
Old 07-23-2001, 11:21 AM
Robin 993DX
Lifetime Member
Post
Sean,
Porsche went to OBD2 in MY 1996, as required by law.
There were no OBD2 993s prior to that.
Old 07-23-2001, 01:39 PM
Ray Calvo
Passed On
Ray Calvo's Avatar
Post
I agree with Robin. if you open your engine lid and read the engie sticker rthere, as I remeber it sez specifically engine electronics are OBD II.
Shop manual has some description of downloading fault codes stored in the computer without using a scan tool. Buy the shop manual and look in "Diagnosis" volume.
Old 07-23-2001, 01:43 PM
Ray Calvo
Passed On
Ray Calvo's Avatar
Angry
DAMN!!!!! One of these days I'll learn to type and review what I write better before sending!
Should have said "if you open your engine lid and read the engine sticker there, as I remember it sez specifically engine electronics are OBD I."
2nd paragraph still OK.
Old 07-23-2001, 03:04 PM
Robin 993DX
Lifetime Member
Talking
Hey pops,
You know you can just edit the first post and correct your mistake instead of making another one.
We all love your posts and all, (:P) but too much of a good thing gets "old" quickly....
ROTFLMAO LOL!
Old 11-09-2013, 09:59 PM
Age100
Age100's Avatar
So is there any On Board Diagnostics on pre 95 cars, I have just ought a 94 993 and interested what data I can extract if any?
Age
Old 11-10-2013, 08:56 AM
Nurburger
Nurburger's Avatar
http://www.durametric.com/buyus.aspx
Old 11-10-2013, 12:48 PM
BobbyT
BobbyT's Avatar
You can read the codes on an OBD I 993 without a code reader.
1. Turn on the ignition, but don't start the engine.
2. Depress the accelerator pedal fully for about 3 seconds.
3. The CEL will illuminate steady, and then begin to flash.
4. Ease off the accelerator pedal, and read the codes.
Each code consists of four digits, such as 1121. Each digit will be a number of flashes followed by a pause. Example: Flash pause flash flash flash flash flash = 1500, which means "no fault found". There may be multiple codes. You should have a single flash then a pause, then a single or a double flash. If the flash is double then the fault is intermittent (loose contact) otherwise the fault is constant. And then the following flashes;
11 Supply voltage
14 Engine temp sensor 2
15 Throttle potentiometer
18 Rpm signal
19 Speed signal <- Speedometer
21 Hot Film Mass Air flow sensor
22 Oxygen Sensor (Signal)
23 Oxygen regulation
24 Oxygen sensor
25 Intake Temperature Sensor
26 Ignition timing change
27 Opening winding of idle stabilizer
28 Closing winding of idle stabilizer
31 Knock sensor 1
32 Knock sensor 2
33 Control unit faulty
34 Hall signal
36 Idle CO potentiometer
41 Control unit faulty
42 Fuel pump relay (DME-relay)
43 Tank ventilation relay
44 Air Pump
45 Check Engine warning lamp
51 Injection valve cylinder 1
52 Injection valve cylinder 6
53 Injection valve cylinder 2
54 Injection valve cylinder 4
55 Injection valve cylinder 3
56 Injection valve cylinder 5
67 Ground and plug connections
69 Ground and plug connections
A MAF failure would look like;
FLASH pause FLASH pause FLASH FLASH pause FLASH
Or, you can buy Tore's excellent OBD interface, download the Scantool software (developed by rennlisters!), and see pretty much everything electronic the car is doing on your laptop:
http://www.bergvillfx.com/products.html
He also makes an excellent HID conversion, and gives a rennlist discount.
Old 11-10-2013, 09:02 PM
nine9six
nine9six's Avatar
11 Supply voltage
18 Rpm signal
24 Oxygen sensor
31 Knock sensor 1
32 Knock sensor 2
34 Hall signal
44 Air Pump
BobbyT,
Can you please clarify something for me?
Is Tore's unit for OBD 1 only, or will it also work with OBD II electronics as well?
Thanks in advance
Old 11-10-2013, 09:05 PM
gonzilla
gonzilla's Avatar
Bonus points for the >12 year old thread resurrection.
Old 11-10-2013, 09:29 PM
Ed Hughes
Ed Hughes's Avatar
No brainer-Tore's setup.
Old 11-10-2013, 10:29 PM
BobbyT
BobbyT's Avatar
nine9six,
Tore's website says, "Works with Porsche 993 with OBD2-style connector."
For more details and to confirm, you may want to contact Tore. He's an easy guy to get in touch and to deal with.
Old 11-10-2013, 10:44 PM
techman1
techman1's Avatar
Works with Porsche OBD1 and OBD2.
If your OBD1 car does not have the trapezoidal connector and has the round one, I believe he has an adapter.
On my 1995 US version, the scantool software and hardware works. There are challenges if you have the driveblock system like the US version. I believe Tore has more info.
His interface is a quality piece of equipment.
Quick Reply: OBD II Scan Tool For 1995 993 ??
