Pirelli Flat-Spot ruins driving...
![Red face](https://rennlist.com/forums/images/icons/icon11.gif)
Over the last couple of weeks my car has begun to develop a persistent vibration between 90-130 mph and at all speeds has begun to pull to the left.
This has been getting worse recently and yesterday I noticed that at very low rolling speeds (sub 5 mph) I can actually see the front left wing rising and falling by 5-10mm as the wheel turns...
So I recon I have a flat spot on my front left Pirelli.
But, would this cause the pull to the left as well? Is there a way of testing to be sure that it is a flat spot? If it is, should I change the tyre for a new one (annoying as it has only done 1000 miles)? WHY do they do this?!
All help gratefully appreciated. Many thanks, Will.
Hi,
Surely the wing rising and falling has to be a suspension problem. I'm not a mechanic but I find it difficult to equate flat spots with the wing rising and falling.
Tito.
Tito.
[quote]Originally posted by WillBank:
<strong>Tito... gd point. Not one I wanted to hear but I suppose you are right... what could cause it on the suspension front???</strong><hr></blockquote>
Bad Shock maybe.
But I have had a bad set of Pirelli's and have heard of others as well. Swap the tires out first and hopefully that will solve it. Get your tire dealer involved, hopefully they will get Pirelli to replace them if they are the problem.
Greg
Bad Shock maybe.
Greg
![Wink](https://rennlist.com/forums/images/icons/icon12.gif)
Willbank, I think your original thoughts were right. Why don't you jack up the front and try turning the wheel, look for the flat spot (or bent rim!). Suspension can't really cause this, although something awry with your (front) all wheel drive might ??
You could always get it up on a hoist with all wheels rolling (sounds like something from a **** site!). Just some thoughts, anyway - cheers, Maurice.
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
