M030 question
Hello all!
Gert's M030/Bilstein HD kit includes the following:
Bilstein HD shocks for front and rear.
RoW M030 springs.
22 mm stabilizer bar for the front
2x 22mm rubber bushing for the front stabilizer
drop link left for the front stabilizer
drop link right for the front stabilizer
special bolts
20 mm stabilizer bar for the rear
2x drop link for the rear stabilizer
2x 20mm rubber bushing for the rear stabilizer
I found out that my car is a M030 (US) car after I had already made the deal
Are all the parts except for the Bilsteins and RoW springs already on my car or do I need the entire kit?
Thanks!
RoW M030 springs.
special bolts
Are all the parts except for the Bilsteins and RoW springs already on my car or do I need the entire kit?Thanks!
Not to worry...you have US M030 on the car. What Gert has sold you is far superior. Why even Viken runs this set up. You know that Viken is pretty picky. See the following from
<a href="http://www.schatzmotorsport.com" target="_blank">http://www.schatzmotorsport.com</a> (Mike Schatz)for clarification.
Mike writes, "The U.S. version for 993 M030 suspension is not much different from the standard suspension! It includes slightly stiffer shocks, slightly larger sway bars and 17" wheels."
________________________
TOTALLY DIFFERENT THAN THE MO30 US MONROE SHOCKS,
RoW M030 springs.
DIFFERENT THAN THE MO30 US SPRINGS RE. RIDE HEIGHT AND PERFORMANCE.
YOU PROBABLY HAVE A SMALLER BAR WITH US M030.
special bolts
YOU PROBABLY HAVE A SMALLER REAR BAR.
Do not worry. You have bought the right thing from Gert. And, since your car has only 11,000 miles on it, I am certain there will be some willing chap to buy the M030 US suspension after it comes off the car.
Dont foget to order that 993 Aerokit 1A front splitter from Gert, or sell off the tail and the side skirts and upgrade to the 993RS look all around. I might be talked into that 993 Arerokit tail
...I already have the 993RS front splitters and side skirts mounted. I prefer the 993RS front and side look in contrast to the 993 Aerokit look. I do like the 993 Aerokit tail.
<img src="graemlins/xyxwave.gif" border="0" alt="[bigbye]" />
RoW M030 springs.
special bolts
...I already have the 993RS front splitters and side skirts mounted. I prefer the 993RS front and side look in contrast to the 993 Aerokit look. I do like the 993 Aerokit tail.<img src="graemlins/xyxwave.gif" border="0" alt="[bigbye]" />
[quote]Originally posted by Martin:
<strong><a href="http://wwww.schatzmotorsport.com" target="_blank">http://wwww.schatzmotorsport.com</a> (Mike Schatz)for clarification.</strong><hr></blockquote>
Martin
Extra "w" in the URL causes error - you might wish to edit it.
Martin
