To fill or not to fill the bumperette holes....
Originally posted by 99D3C2
How do you simply "fill" the bumperette holes? Won't any filler you use on such a large and non flat surface eventually come loose and fall out..
Originally posted by viperbob
Anything faster than 5 MPH and that aluminum will fold up anyway. ....The front with the shocks weighs 22lbs and the rear comes in at 35 with the bumperettes if I remember correctly.
My thanks - honestly - I think I'll lose them... I need to remount the hose for the headlight washer (keepers to the trunk wall) and mount the sensor where the A/C was. Other then that - it looks like a straight "off mount" proceedure...
I'll keep taking pics in case anyone is interested....
Thanks again!
Originally posted by Livefreeandrive
John, I love the way you just TEAR into a project!!!!!!.....
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Honestly - I love my 993.. It's what I've always dreamed of owning someday... And - for $16K - there were some "warts" - but now I'm on the path of "upgrading" those warts
BTW - after the engine rebuild I did.. Ready?? From NH to OH - and back (2400 miles roundtrip - including the 200 mile "spirited" rally) - I burned a whole 1/4 quart of oil. Damned if I know where that 1/4 quart went in 2500 miles - it didn't leak a drop..???
Best to you!!!
John,
Please picture chronicle your way through your bumperette removal for us that are less than talented. I to would like to lose mine, but have no idea where to start to do this except take it to a body/paint shop.
Rock on!
Rock on!
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
How do you keep the euro lenses on with out the bumperettes ?
Addict & Guru
The lenses are not held on by the bumperettes. Protrusions on the back of the lens slide into matching body slots & then the 1 screw holds it in place.
John,
I know that the body is still warm BUT...if you decide to get rid of your clear standard length lenses....I'd be willing to purchase them from you....
In fact...on that note...I really think that you should go with the Euro lenses...DEFINITELY a better look....hehe
Actually, one day when I grow up, I want to change over to a Turbo bumper and go w/o the bumperettes as well.....must.....arrgh...slow.....down...the.....descent...down....this .........slope.....
Originally posted by John D.
Hmmm - I actually thought of that - looking at that HUGE DAMNED THINGY....
John
John
Originally posted by kkim
John,
Please picture chronicle your way through your bumperette removal for us...
John,
Look for pics in this thread as I complete this project..!!!!
Hey John,
Early day for me but while you are sleeping, I looked at your front minus bumper cover.
The headlight washers are fully exposed.. rip the suckers off
IMO.
Let's see what the consensus is now.
Originally posted by Monique
Hey John,
Early day for me but while you are sleeping, I looked at your front minus bumper cover..... The headlight washers are fully exposed.. rip the suckers off
Hey John,
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Hmmm - headlight washer/jets..?? They never worked anyway - and the motor is shot.. For 993 without those washers - did the factory use a plug, or were the fenders never cut with a hole???
Thanks!!!
I just left the nozzles in the bumper, but mine is black so they really did not show. I then removed the washer tank. Saves about 10 lbs of plastic and 2 small motors. Also saves another 6 lbs since it requires almost a gallon of fluid to keep the low fluid light from coming on. So a 16 lb savings high in the fender and far forward. Go John Go...... Take it out......
.....So a 16 lb savings high in the fender and far forward. Go John Go...... Take it out......
Sorry John..
Did not know it reduced weight so much.
The RS does not have any light washer holes.
Go for it, your path is open.
BTW, great job for this board. Think me not alone in thinking this. Well done mate.
