993 Forum 1995-1998
Vevor lift alternative to quick jack?
Old Nov 18, 2024 | 10:47 PM
chsu74's Avatar
chsu74
Default Vevor lift alternative to quick jack?
Anyone seen or use this lift before. Design is straight up and down so that you don’t need to accommodate extra room for the swing action quick jack requires. This allows one lift to service all of the cars in your garage.
https://m.vevor.com/clearfloor-lifts-c_12244
Old Nov 19, 2024 | 07:48 AM
95_993's Avatar
95_993
My only reservation would be accessing passenger side sill for oil changes on the 993.
I went with the Bend-pak mid-rise. Has worked well with 993 and variety of daily drivers. Only downside is that my 993 sits too low to clear the list when down so I use race ramps. L
File Type: jpg
Old Nov 19, 2024 | 08:58 PM
chsu74's Avatar
chsu74
Howdy! Long time.
That is an option but I don’t want to spend $3K+. I know it opens up easy motor drop. This is $1500 all in(including all accessories) and you can manage it to raise it to clear 28” for engine out work. Quickjack will be $2K. $2K means go midrise like yours imo.
Is RL slow nowadays or owner profile have changed? I haven’t been here for maybe 18-24 months+
Old Nov 20, 2024 | 08:29 AM
95_993's Avatar
95_993
Originally Posted by chsu74
Howdy! Long time.
nice to see you (virtually) as well! I found mine used (barely) from an older retired guy that used a couple it a handful of times to change the oil in his vette. Grabbed a u-haul trailer, loaded it up…came with the race ramps. Check the local listings. It’s worked great for several engine drops.
Old Nov 20, 2024 | 09:04 AM
71-3.0-911's Avatar
71-3.0-911
If you're in the $2k range, check out Twin Busch mid rise scissor lift. I've had mine for about 3 years now and love it. Another option worth pursuing...
