Wheel Fitment
I know this has been discussed before and is on Robins site, but I could not find anything on the following size:
Will a 9.5x18 ET40 fit on the rear of a narrowbody 993? If not, will spacers help or rolling the fender?
I am looking at putting 265's on them.
David:
The rear wheel will stick out by 1/2 inch and depending on what negative camber setting you have, it may not even stick out that much.
Are you getting tired of the B&B Triflo yet?
If you compare this wheel with the factory 10" x 18" ET65 version, it will stick out another 18.5 mm (~3/4") but the inside edge will be fine. I would guess that you don't have room under those fenders except, as Ron says, if you have a lot of negative camber. Unless you can test fit them, I would stay away from these wheels.
Thank you for all of the responses. These wheels are from a 996 and are out of state, so I will not be able to try them first.
They are a terrific price for great wheels that I was looking to potentially put some track tires on. At such a great price, it is tempting to try and if I don't like the fit I guess I could just try to sell them.
Note that I have about 1.5 deg's of negative camber in the rear. I have tried measuring and you are all correct that it would be a tight fit. I just added 3/4" to my existing wheels (10x18 ET65 Turbo wheels).
