Wheel painting like a pro
Of course you need a air compressor to power your brush. Be sure and get the best breather or resperator that home depot sells!!!! I can go into more detail if you would like. but I just used my helmet stuff to do the wheels. The wheel one the left is the wheel I did and the one on the right is the factory job. BTW I have time to do more helmets if anyone is interested.--here is one pic without flash:
Give me till tommorow morn, because I will finish up around 10PM
CDT which is Central Dallas Time
It drives my wife crazy. now I am thinking I could do a complete respray of my hood and bumper myself!! I would have to build a better booth. but hey
But look at the other guys!! Our main man John D is got his car completely apart and putting in all kinds of mods! Ok OK so he hasnt started it yet. but the pictures are fantastic!!
but, Its still accurate. The main difference with pro supplies and rattle cans in my opinion is the 2 part clear coats available to the pros. The rattle can paints are lacquer or enamel and don't stand up as well as the epoxy or 2 part paints.
If you don't have spray guns and compressor, Wurth Silver is a good match and you can clear coat after it dries for a couple of days. Don't use wurth clear lacquer on wurth lacquer silver too soon or it will wrinkle!
An alternative, that I haven't tried with a wurth silver base coat, but worked well on PPG base coat is a 2 part clear from a spray can. 2 Part (2K), SprayMax Urethane Aerosol Clear Coat comes in a can and has a 24 hour shelf life after it has been activated. This will be as hard and durable as the factory paint.
If you want to try this approach paint your wheels with wurth silver from a spray can. Also paint a test panel with the same paint. Let dry for two days.. Then activate the 2 part clear in the can. Lightly spray the test panel with clear. Let dry 10 min or so. Follow up with heavier coat that will flow out for nice gloss. Let dry 1 hour. ANY reactions? if not, spray your wheels with the 2 part clear. First light then heavier coat. the light coat is to protect the lacquer from reacting with the heavier gloss coat.
Professional results with rattle cans!! Hope this works for you. You need to test this because my experience with the 2 part spray can clear was over urethane base coat so I had no bad reactions. I have not tested 2 part clear over lacquer but the directions on the can say it should work.
The Clear is available at auto body paint supply shops. Here's a link to read about it
http://www.repaintsupply.com/pd_2_part_2k_aerosol.cfm
BTW, those Wurth Silber spray rattle cans seem to have a 'shelf life' of zippo. The paint very quickly 'clogs' the esoteric cap (not like a normal rattle can cap) leaving you with a half-rattle-can and a clogged 'delivery system'. As y'all know, the LAST thing u need is a 'spitting' spray can -- so caveat emptor!
Gerry
