993TT oil change
I have a question for you guys, how much should an oil change be for a 993TT. I got quoted about $175-$200 from aPorsche dealer and about $200 from an independent shop. Does this sound right
viperbob is right. In addition, you need to verify that each turbo drains the same amount of oil. If not, that may indicate a problem with the turbo seal.
Here is my updated DIY ( based on Robin's DIY ) for TT's.
<a href="http://www.cuberootconsulting.com/~jchan/oilchange/" target="_blank">http://www.cuberootconsulting.com/~jchan/oilchange/</a>
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by AC:
<strong>How hard is it to change the oil in the turbo</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Just unscrew the drain plug in the turbo, replace the washer, then reinstall the drain plug. It'll probably take you about 1-2 minutes per side.
Thank you everyone for your advise and help.
I decided to take the car to the P-Car dealer, because I still have about a month of warranty left on the car. I took the car in over the weekend (Jack Daniel Porsche Paramus, NJ) to get the oil changed and it cost about $200. I took it in so that they can check the whole car over, and it pass with flying colors. The only thing they saw was a missing lug, which I had in my possession because I wanted to order a polished set, other than that the car didn't need anything else done (knock on wood). I will try to do the next oil change myself. Thanks again
