993 Forum 1995-1998
993 Battery Replacement
Old Sep 21, 2024 | 08:59 PM
radaporsche's Avatar
radaporsche
Default 993 Battery Replacement
I'm trying to replace the battery on a 993 (1995) and was expecting it to be straightforward but after removing the ground and positive terminals, it isn't budging.
I can't find any threads or videos that are detailed, but there seems to be conflicting info on if the spare needs to be removed (and one person who tried that, could not get the spare to move either (https://www.pistonheads.com/gassing/topic.asp?t=1201744) ), and if there is a bolt somewhere that needs to also be removed. This thread says there is, but isn't clear on where it is and doesn't mention moving the spare at all (and even shows it in place) https://rennlist.com/how-tos/a/porsc...battery-377041
Anyone have experience that can help guide me? Thanks!
Old Sep 21, 2024 | 11:33 PM
HalfGerman's Avatar
HalfGerman
Remove the spare wheel, part where wheel is closest to battery ( under that ) is a bolt and bracket at the base of the battery.
Battery Bolt shown is about 10 secs, also around 1:18 mark, in this video ( found on a quick search). Also at the 1:18 mark ,you can also see the large gold washer and bolt that holds the spare wheel on. Sitting on the floor of the frunk.
Again battery bracket shown at the 3:43 mark in this video:
Hope that helps
Harold
Old Sep 22, 2024 | 06:00 AM
orangecurry's Avatar
orangecurry
There should also be a battery gas/vent tube, so pull that out of the battery (on one of the top edges) before you lift the battery out.
Howver this may well have not been re-installed when the battery was last replaced. If you find a clear plastic 5mm tube lying around in that corner, you'll know what it is now
Old Sep 22, 2024 | 06:46 AM
orangecurry
All batteries on all cars have a clamp/retention of some kind - no installation should rely on only the cables holding it in place.
Vent tube top right - clamp at bottom - 13mm bolt?
Old Sep 22, 2024 | 10:52 PM
radaporsche
Hope that helps
Harold
This is super helpful. Thank you. Would you know if it is straightforward to remove the spare? The other link I shared (https://www.pistonheads.com/gassing/topic.asp?t=1201744) talks about how he was having difficulty getting the spare bracket to move as well.
Old Sep 24, 2024 | 10:38 AM
HalfGerman's Avatar
HalfGerman
Spare was pretty easy, just that one bolt /large washer in the middle of the spare wheel.
7 Porsche Models That Have Aged Like Fine Wine
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
