Replacing rear bumper cover - what to do with rivets when putting rear cover back???
Rivets are used all over the rear bumper cover: retaining strip(4 rivets), l/r lateral/lamp heat shields(8 rivets), retaining brackets(12 rivets). It is being suggested to drill out rivets to take old rear bumper cover off the car. But I could not find suggestions on how to put those pieces back together with your new bumper cover:
- do you rivet them using new rivets(you can buy OEM Porsche rivets, it's not a problem, but what kind of tool you are supposed to use? is it possible to get a hold of such tool?)
- do you use something else? I saw 964 guys used sheetmetal nut with self-taping screw(the same thing, that holds, for example, right/left rear turn flashers) in place of front bumper rivets.
Thanks!
Thanks!
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Just get new rivets (aluminum pop rivet) and install with a pop-rivet gun. They are not expensive (save for nicer ones) and really easy to do..
I bought my pop rivet gun at Sears and it worked great with the Porsche OE rivets. Very easy job to drill out the old rivets and replace the heat shields and the metal protection bar.
