I am trying to install a CDR 210 in my '95 and I am not sure it is fitting correctly into the dash opening. Would someone do me a favor and post a closeup pic of their CDR 210 so I can see what it looks like in someone else's dash? Thanks in advance.
I don't have mine in the car anymore (therefore no ability to take pics), but it fits just fine straight into the dash. It may stick out 1/4" or so, but that is correctly installed and sitting in the dash.
If you take a pic and post it, I'll tell you if it looks installed correctly.
Here you go. When I first saw the title of the post, I thought there were pics of YOUR CDR-210 and therefore I skipped it because I have seen one before
thanks for the pics. I definitely need to try my install again because mine was sticking out further than yours. Thanks for all the other replies as well. This board is great!
Max
Randy # 1, dmbgamer, is trying to install this in a 95C2, which is what I also have. I have read numerous threads and the question is still unclear whether this is a direct swap between the later models and the 95, which came with the CR-1 radio.
My recollection is that the left lower corner of the radio is supported by a bracket that the radio slides into and rests on. There is a large black wire bundle in that vicinity and sometimes that bundle gets between the radio and the bracket. This will prevent the radio from going forward where it belongs.
I had my independent Porsche shop swap my CR-1 for the CDR-210 when I had the car in for the 60K service. They didn't know a lot about Porsche stereos, so I just told them to see if they could make it work. They told me later it wasn't much of a problem, and I didn't get the impression that major surgery was required. Mine looks exactly like the photos in Randy M's post.
