Oil cooler fab update
Chris I was thinking of buying a cooler core off the shelf. Have you guys used setrab, permacool or earls? I am leaning towards Perma cool right now because they have side inlet and outlets. Earls appear to be top inlet/outlets. The hoses should not be a problem except for the connectors. thanks for the links!
Originally posted by OldGuy
Couple that with two boys 14 and 9 who are fixing everything from skateboards, to motocross bikes(even if they're not broke!!)
Hey OG. Here is a garage-cleaning-out stategey that has worked for me.
Put everything in boxes and put todays date on the box. In one year, if you have not opened the box, you don't need it.
Now here is the important part:
Throw it away WITHOUT OPENING THE BOX.
