Private Message Pop-Up Box
Keeper of the Truth
Originally posted by Robert Henriksen
How odd - I just got a pop-up notification of a PM, but when I went to the PM mailbox, there was nothing new. Maybe the system got re-initialized, and it was just catching up?
Aww - shoot. Sorry about that.. I posted the reply below to another Forum where the same subject came up...
Originally posted by John D.
Sorry guys - should have warned you....
Yea - I'm doing some tweaks to the code right now in preparing for a rather substantial "upgrade" in the near future.. You should only get that box once as I reset the code - then all should be "normal" - well, whatever "normal" is suppossed to be.
You can also disable/enable the PM pop-up in your profile....
JD
JD
Ah Ha! The culpret is revealed. Got to watch out for those guys with white 993s.
Thanks, John
BTW, for those whose pop-up still isn't working -- my pop-up filter was causing part of the problem. When I added "forums.rennlist.com" to the "white list" of sites from which to permit pop-ups, it worked. Check your pop-up filter.
Thanks, John
