993 Forum 1995-1998
Car runs rough after getting on it
Old 06-22-2004 | 12:21 PM
garychios's Avatar
garychios
Default Car runs rough after getting on it
Car runs nice when she starts, Idles nice, and makes tons of power when I get on it, but once I let off the gas, she runs a bit rough, (not a miss) and then clears up again after a while. A while is the key word. Any Ideas?
I am thinking plugs and or 02's. I just dont want to start replacing stuff if I dont have to.
Old 06-22-2004 | 12:26 PM
John D.'s Avatar
John D.
Have you tried cleaning the ISV?
Old 06-22-2004 | 01:08 PM
garychios's Avatar
garychios
Is the ISV the piece on top of the varioram, which seems hard to get out, because the body of the car is in the way? It has some tube attached to it or somthing?
Old 06-22-2004 | 01:18 PM
John D.'s Avatar
John D.
Yep - that's the one..
OK - it has an electrical connector, and an "inlet" and "outlet" connected with rubber hoses. To remove it - unclip the electrical connector (grey plug), and loosen the two hose clamps (one is in front of you and the other - directly behind it). The sound panel will give you enough room to get it out.
When it's out - use brake cleaner and cotton swabs to flush it out and clean it.
Let me know if that makes sense, OK??
HTH!
Old 06-22-2004 | 01:23 PM
garychios's Avatar
garychios
Sounds great, I hope this works. Thanks a million
