993 Forum 1995-1998
Where is the fuel pump located from the factory?
Old 04-14-2024, 06:03 PM
cairo94507
cairo94507's Avatar
Default Where is the fuel pump located from the factory?
HI All,
I have a '95 3.6 993 engine going into my '71 914-6. I bought the engine removed from the 993. It came with the fuel pump. I located it under the engine shelf, next to where the engine will install. I have now heard this fuel pump should be mounted near the fuel tank (front of the car) instead of next to the engine. Where was the fuel pump mounted from the factory in a 993? Thanks for your help.
Michael
Old 04-14-2024, 07:27 PM
71-3.0-911's Avatar
Under the car next to the steering rack. Accessed through small door to drivers side of tunnel.
Old 04-14-2024, 10:22 PM
boomboomthump
boomboomthump's Avatar
Here's a link that has some pics. As mentioned,front of the tunnel, just off to the side. Right above it is the bottom of the fuel tank. The pump is connected to it by a short hose (less than a foot).
https://www.pelicanparts.com/techart...eplacement.htm
Old 04-15-2024, 09:20 AM
95_993
95_993's Avatar
Yes, almost all electric fuel pumps are designed to "push", not "pull" so close to the tank, slight below, horizontal location. Sounds like an awesome build. Love to see/hear more.
Old 04-15-2024, 10:19 AM
boomboomthump
Just thought I'd add another visual for you...
This is the area on the other side of that trap door that holds fuel pump. The low spot in the fuel tank sit in there. The pump is on a bracket with a few inches of hose connecting it to the bottom of the fuel tank.
Old 04-15-2024, 11:57 AM
cairo94507
cairo94507's Avatar
Thank you all; I appreciate the information and help. I will relocate my fuel pump under the gas tank.
Old 04-15-2024, 12:31 PM
pp000830
pp000830's Avatar
Received 1,461 Likes on 1,030 Posts
Hi Cairo,
Putting it near and below the gas tank allows the pump to push fuel rather than pull fuel. Probably to avoid vapor lock and to avoid the need to prime the pump when the system goes dry. The pump is also cooled by the liquid passing through it so one wants to avoid it running dry.
Andy
Quick Reply: Where is the fuel pump located from the factory?
