993 Forum 1995-1998
993 Cruise not working
Old Mar 9, 2024 | 01:59 PM
Burky's Avatar
Burky
4th Gear
Default 993 Cruise not working
I have a 97 911. My cruise started malfunctioning by not turning off by touching the brake. Then it just stopped working. I have seen allot on reworking the solder in the brain box but I don’t know where it is located. Any help, please.
Old Mar 9, 2024 | 02:25 PM
systemsc's Avatar
systemsc
Former Vendor
It's located under passenger seat. The earlier 911 (pre-964/993) cruise control ECUs were less reliable because of solder connections, than the later ECUs. Hopefully, you don't have water damage under the passenger seat.
Old Mar 9, 2024 | 09:21 PM
Burky's Avatar
Burky
4th Gear
Thank you for the location. I don’t think it would have been wet, we’ll see. I have repaired solder joints in my wife’s car’s heater display successfully so I’ll give it a try.
Old Mar 10, 2024 | 01:17 AM
systemsc's Avatar
systemsc
Former Vendor
Before soldering, you might consider checking key inputs, e.g. the speedo, brake lights, multiple powers, and the motor/clutch assembly.
Old Mar 10, 2024 | 12:54 PM
pp000830's Avatar
pp000830
Hi Burky,
Be aware replacing the stop light incandescent bulbs with LED bulbs will cause the cruise control to not work as it needs to see a resistive load on the circuit to work, LEDS do not provide this.
Knowing this, I would check that the tail lights are incandescent and are working properly as a faulty brake peddle switch or blown-out bulbs that reduce or eliminate the resistive load on the brake light circuit might cause the cruise control to become squirley when trying to activate it or trying to press the brake peddle to disengage the system.
Andy
Old Mar 13, 2024 | 11:55 PM
kb's Avatar
kb
If your car is a stick shift; depress the clutch all the way in, then put your foot behind the clutch pedal and push it up towards you. Sort of lifting the clutch pedal up. Sticks sometimes. Hope this helps you. Happened to me a few years back and our “ dear friend SW” taught me that trick. Still schooling us after all these years.
Old Apr 28, 2025 | 11:06 AM
Earlierapex's Avatar
Earlierapex
Similar problem, 96 993 EU turbo. Cruise control just quit - won't "set" a speed. Should I start with fuses?
Old Apr 28, 2025 | 01:15 PM
sdm100's Avatar
sdm100
What’s cruise control
7 Porsche Models That Have Aged Like Fine Wine
Old Apr 28, 2025 | 02:35 PM
M. Schneider's Avatar
M. Schneider
25 Year Member
Originally Posted by kb
If your car is a stick shift, depress the clutch in, then put your foot behind the clutch pedal and pull it up towards you. Lift the clutch pedal up. Sticks sometimes. Hope this helps you. It happened to me a few years ago, and our “dear friend SW” taught me that trick. Still schooling us after all these years.
" That's a Bingo" .... The clutch and/or brake pedal micro-switch is often the culprit. ... Do as KB says.
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
