sunroof button
My sunroof button got pushed through the console. <img src="graemlins/cussing.gif" border="0" alt="[grrrrrrr]" /> Any idea on how to fix? I assume I need to take the console off.
TIA
TIA
nope, don't have to remove the console. Just pop off the top pannel off (lift by hand) than the lower pannel off (where the sun roof switch is mounted to). The pannels are held in by spring loaded clips.
The control panels just pull off with your fingers.
Here's a DIY from EJ that describes how to take off the panels. <a href="http://www.pcarracing.homestead.com/gdo.html" target="_blank">http://www.pcarracing.homestead.com/gdo.html</a>
Then the switch just snaps into place on the back of the panel.
I think that when you see it, it will be obvious.
Jeff
Jeff
