993 Forum 1995-1998
Slotted rotors for 993?
Old 03-26-2003, 12:59 AM
914und993
914und993's Avatar
Post Slotted rotors for 993?
Are slotted rotors available for the 993? Granted they don't look as good, but my understanding is that they equal the performance of drilled rotors but with less of a heat stress cracking problem.
I've never seen them advertised for the 993, and have wondered if there was a particular reason.
TIA
Chip
Old 03-26-2003, 01:05 AM
kary993
kary993's Avatar
Post
The research I did on this about a year ago was that regular carrera brakes only had OEM cross drilled. If you have big reds you could get cross drilled, slotted, or both.
Old 03-26-2003, 12:57 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Post
Chip:
All of the OEM Brembo rotors come with the cast-in holes. The only slotted rotors that you might buy would be either racing rotors from AP and Alcon or some racing Brembos, and all of these require a custom billet hat for these cars.
These will be FAR more expensive than the OEM rotors.
Old 03-26-2003, 01:26 PM
tom_993
tom_993's Avatar
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by 914und993:
<strong>Are slotted rotors available for the 993? Granted they don't look as good, but my understanding is that they equal the performance of drilled rotors but with less of a heat stress cracking problem.
Chip</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Chip,
From what I’ve heard, this is correct. Slotted rotors will actually give slightly better performance due to greater surface area and they are less prone to cracking. However, drilled rotors are lighter, cool the rotors better, and are easier on brake pads.
Tom
’95 993
Old 03-26-2003, 09:51 PM
914und993
914und993's Avatar
Post
OK, thanks guys. I'll put slotted rotors out of my head now.
Chip
Old 03-26-2003, 10:06 PM
Strabo
Strabo's Avatar
Post
Who makes slotted rotors for big reds?
Strabo
Quick Reply: Slotted rotors for 993?
