Throwout Bearing for lightweight flywheel kit
I am in the process of gathering parts for a lwfw on my 993tt. In reviewing this forum, it seems like there are 2 part numbers that get floated around for the throwout or release bearing.
They are:
95011608009
and
94411608001
Both seem to be mentioned as working, but I"m not sure how thats possible. Anyone have insight on the correct part to use for the standard LWFW setup (including RS4.0 disk)?
Thanks.
They are:
95011608009
and
94411608001
Thanks.
I'm using the 944 116 080 01 Sachs clutch bearing on a 993 turbo with a turbo pressure plate, disk and a lightweight flywheel. I have no problem with, Make sure you use the smaller pinion sleeve the bearing slides on.
