Engine Mount difference: 99337504908 vs 99337504909
Looking to replace my stock engine mounts with non-RS versions (not a track card anymore), I see these two OEM choices. Are they both hydraulic or is one rubber?
Also do I need the hardware bolt kit?
This one is $656
https://www.fcpeuro.com/products/por...or-99337504909
And this one is $276;
https://www.fcpeuro.com/products/por...nt-99337504908
Recent posts indicate these guys are OEM supplier to PAG, so is this one rubber?
https://www.prekom-usa.com/product/p...ine-mount-kit/
This one is $656
Those 'OEM' mounts don't look great quality from here - I could well be wrong of course.
However the Prekom mounts are very high quality and those are 'rubber' solid versions. They are probably the version with a 65-shore hardness value, i.e. 'standard'. Prekom don't do any multi-material mount - they do solid rubber or monoball etc.
The other Prekom version has a 75-shore hardness value, which is what is used in the RS Models.
I chose 75 - it's been superb.
SonnyT (11-27-2023)
I think I'll go with the Prekom 65
You might like this price a lot better, 09 version , Rein:
https://www.autohausaz.com/pn/RE-99337504909
Hell of a price spread between the FCP and Autohaus AZ.
